How to resize images in batch without losing quality
Resizing images or photos in batches can be very useful to reduce the weight of the files without losing quality, and be able to share them quickly. WithXnResize, you can resize many images easily with a couple of clicks in a simple interface.
XnResize exists for Windows (8.0, 8.1, 10), macOS (10.12+) Linux and supports more than 500 different file formats, from popular formats like JPEG, PNG, TIFF or PSD to various digital camera photo RAW formats and new formats such as WebP, HEIC, JPEG 2000.
After installing XnResize, and starting it, you can see the main interface.
XnResize: Main interface
You can import the images from your computer one by one, or by importing directly a folder.
XnResize: Importing images
You can change the view mode of files, for example see details of images. And sorting them by clicking on the header.
XnResize: Viewing mode
In this tab, you can choose the output dimension, and the mode of resizing:
You can choose the resample method and apply a gamma correction on the resized image.
Another option is to change orientation of images.
XnResize: Resize settings
By clicking "Next", you go to "Output" tab. In this tab, you can set the output folder, choose a template name for output filename, or choose output format.
In the options group, you have important settings like
XnResize: Output settings
You can change settings for output format like JPEG, PNG
XnResize: Formats settings
Once you have modified all desired settings and parameters, you can convert your images by clicking on "Convert" button.
During conversion, the tab "Status" is shown and you can see the progress.
If there is an error, you will see it here.
XnResize: Batch convert
